I try to use Move Binary Data node to convert received email to .eml file .
but when i check file info by cortex. it seem remain as JSON .
Please see attached images.
Thank you for your continuous support .
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
- **n8n version:**0.214.3
- **Database you’re using (default: SQLite):**default
- **Running n8n with the execution process [own(default), main]:**default
- **Running n8n via [Docker, npm, n8n.cloud, desktop app]:**Docker
