Using PIL on the code node (Python)
Hello,
I’m trying to follow the solution listed here:
Which downloads an image and then uses the code:
from PIL import Image
import io
import base64
binary_data = _input.last().binary.data.data
decoded_data = base64.b64decode(binary_data)
image = Image.open(io.BytesIO(decoded_data))
bw_image = image.convert('L')
bw_image_b = io.BytesIO()
bw_image.save(bw_image_b, 'png')
bw_bytes = bw_image_b.getvalue()
encoded_bw_image = base64.b64encode(bw_bytes).decode('utf-8')
return {"bw_image": encoded_bw_image}
To do basic Python PIL manipulations on the code node, but i’m encountering the error
ERROR: UnidentifiedImageError( PIL.UnidentifiedImageError: cannot identify image file <_io.BytesIO object at 0x1388d30>
Has something changed in the syntax requirements, or am I just running it incorrectly?
Many thanks again! :smiley:
Hey @UnluckyForSome
Have you made sure that the binary_data is using the correct variable for the output from the node before it?
Hi there @Jon, I have a follow up on this question.
I am having a series of excel files which are quite old and I am looking to extract the data using a python script in the “code node”.
I upload the file using a “form node” first, which is fantastic.
  • my second option was to use “extract from file node” but I was not able to go through all the sheets in the document and to slice the data, I seemed to lack this option somehow.
so after many fails I decided to go through a hard coded python script so that I can manipulate and directly extract the data from the sheets (all have the same form).
you can see in the image bellow that I am having issues to access the file. I have used the Methods in the documentation but I cannot have access to the binary or the path to access the file.
_input.item, _input.all(), etc.
can you please tell me how to direct the uploaded file to the code?
this is the error:
Node type
n8n-nodes-base.code
Node version
2 (Latest)
n8n version
1.81.4 (Self Hosted)
Stack trace
Error: ValueError(msg) ValueError: Invalid file path or buffer object type: <class 'pyodide.ffi.JsException'> at PythonSandbox.getPrettyError (C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Code\PythonSandbox.ts:101:11) at PythonSandbox.runCodeInPython (C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Code\PythonSandbox.ts:85:15) at PythonSandbox.runCodeAllItems (C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Code\PythonSandbox.ts:46:27) at ExecuteContext.execute (C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Code\Code.node.ts:155:14) at WorkflowExecute.runNode (C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1123:8) at C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1470:27 at C:\Users\RubenCasillasPacheco\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:2029:11
Is this possible?
Many thanks.
