Hello,
In order to do the login authentication for a program I need to use/paste a file (psrApi.js), this file however users methods like require() and is in need of the module ‘babel-polyfill’… is there a way I can integrate this provided script into my workflow? Because in a next step (the actual authentication code) I will need to make references like psrApi.Authenticate
How will I be able to properly integrate the script? Is there a possibility to use something like the Execute Command node such that I can import the missing functions or the file with its functionalities?
Cannot find module ‘babel-polyfill’ [line 1]
As of now it is just a Code node where I pasted in the psrApi.js file
- n8n version: 1.98.1 Self Hosted
- Database (default: SQLite):
- Running n8n via: Docker:
- Operating system: Linux Ubuntu
