Using variable in Luxon fromFormat
I´m a bit confused about using variables in a Luxon function. From a HTTP request I got a date as a string in DD.MM.YYY format.
Now I want to convert this to a more usable Date format. Luxons DateTime.fromFormat() works great when it is hardcoded:
But when I use a variable from a previous node containing the date string, this doesn´t work:
Can someone explain what’s wrong with my expression? Do I have to enter the variable in another way?
hi,
tried it, works on my version 1.8.2. Here’s the screenshot:
may be related to the version you are using, can you answer the previous question, n8n version, database etc. also if possible can you post your workflow ?
Thank you @slenderwrist for your quick reply.
I´m running version 1.42.2 on docker on Ubuntu 22.04 with a PostgreSQL database. Not quite sure what is meant with EXECUTIONS_PROCESS setting and where to change it.
found the problem, here’s the screenshot:
Datum fields have space at the end thats why fromFormat returned invalidDatetime. i added trim() method and then it worked.
Oh, I can´t tell you how much you helped me. Thanks a lot for this. I think I would have never considered something like this. You made my day :innocent:
