I receive 3 values from the item lists node and want to send them further. How can I make it so that the values do not follow each other, but under each other. But not by taking each value from the array, but by passing everything at once.
- n8n version:
- Database (default: SQLite):
- Operating system:
Hi @KamaR, if you want to send your array in a specific format, you could consider using the join() method which lets you specify how the array elements are concatenated. So if you want your values separated by a new line, you could use an expression of {{ $json.locksmiths.join("\n") }} like so:
A quick heads-up on that node: n8n will remove newlines from most previews in order to display as much content as possible. These newlines still exist of course and will be sent.
@MutedJam ok, how should I arrange them next to each other?
