Very Odd Issues with HTTP Request and Doubles/Floats
I’m having a major issues with n8n. I’m making a HTTP request to the API, the API expect a double but n8n keep sending it an INT, even when hardcoded to a double.
This only happens when the double is a zero value, for example, 66.00, however, 66.01 works without issues.
This issue is not API related as I’ve tried on SwaggerHub and with Insomnia and it works with a zero double (66.00 for example). The issues purely occurs with n8n.
this is the my http request
Its this line that is cause the issue “amount”: {{ $(‘Supabase2’).item.json.payableGross.toFixed(2) }},
It results in “amount”: 66.00,
However, I get this error: “400 - “{"error":{"errors":[{"type":-1,"msg":"Value type mismatch for amount. (Was expecting double, but received type: integer, value: 66)","errors":}],"code":400,"message":"Invalid request"}}””
this is the output of the HTTP request that is causing the error:
  "property": {
    "id": 1692
  "description": "Leak under the sink was fixed with a new pipe.",
  "date": {
    "date": "2024-08-30 10:10:15",
    "timezone": "Europe/London"
    "amount": 66.00,
  "expense_category": 1,
  "contractor": {
  "id": 268,
  "reference": "IS15174131 - IS15174131"
Can anyone help please!?
this is it working in insomnia:
It appears that no matter what I do, n8n always removes the .00 when it is a zero sum, is there a way to override this?
Would be good if someone at n8n could look into this, I’ve had to create a cloud function for the HTTP request to call as n8n just will not allow a .00 through it’s json validation.
Hi @Wayne
Sorry for the late reply!
I was able to reproduce the issue and will make an internal ticket to get that looked at :eyes:
Will post here for an update!
Thanks :pray:
