Wait node on form submitted using an expression to display dropdown
my input is as follows
“dropdown_options_config”: [
“id”: “xsmall”,
“name”: “extra small”
“id”: “small”,
“name”: “small”
“id”: “medium”,
“name”: “medium”
“id”: “large”,
“name”: “large”
“id”: “full”,
“name”: “full build”
when i feed this into my wait node
resume: on form submitted
auth: none
form elements:
field Name: pick_size
element type: dropdown
field options:
option (expression): {{ $json.dropdown_options_config }}
when i execute step the wait node i get a one field input screen (as expected) with the correct prompt.  this input field is a dropdown, but it only contains one line "[object Object],[object Object],[object Object],[object Object],[object Object]
i assume there are 5 [object Object] due to there being 5 entries in the array.
i would like to have 5 choices displayed in the drop down as described in the input json shown above.
any help is greatly appreciated!!!
