We need help with HTTP requests
We need help with HTTP requests. After the HTTP request executes successfully once and returns a normal result, it stops working properly. That is, when the request is sent again, it fails unless the Auth Header is recreated or modified (even if the same old API key is inserted).
Hey @Tar_Tarish hope all is well, welcome to the community.
Would you like to expand on that question? Show some examples of the workflow execution, screenshots, output. Embed your workflow for easier repro too.
