The Web Request node ignores the SET value after 1st execution… Am I missing something very obvious?
I am setting a client name through the initial SET value, which is a placeholder for a future webhook trigger. it will be a single value for the duration of the flow.
at some point I get multiple items in my data, in the final node, web request, I have used the SET node value, but all iterations except first act as if the SET value is null.
Please share the workflow
(Select the nodes and use the keyboard shortcuts CMD+C/CTRL+C and CMD+V/CTRL+V to copy and paste the workflow respectively)
1st execution calls https://webhook.site/0531729b-ad0b-497e-b52b-e22f7ca74557?q=xxx&test=xxx
2nd execution calls https://webhook.site/0531729b-ad0b-497e-b52b-e22f7ca74557?q=
3rd execution calls https://webhook.site/0531729b-ad0b-497e-b52b-e22f7ca74557?q=
and all following executions call the same
- n8n version: 0.149.0
- Database you’re using (default: SQLite): PostGreSQL
- Running n8n with the execution process [own(default), main]: own
- Running n8n via [Docker, npm, n8n.cloud, desktop app]: npm
