Webflow Integration Issues
Hello,
I am having issues getting Webflow to connect.
While my connection WORKED via Legacy v1 (switch turned on in the Webflow credentials screen; does not work when turned off [using v2]), I cannot actually see/access data via the connection–I get this error:
  • There was a problem loading the parameter options from server: “[object Object]”
Help appreciated. Thanks.
Hey,
i guess you switched from the v1 token based connection to the v2. The v2 connection should be done via OAuth. You set up the OAuth connection to Webflow in your credentials?
