Hello, I am experiencing an issue with creating a workflow; it seems that the webhook node is unable to fully receive JSON, as the body part is empty as I have attached below. Could you please assist me?
It looks like you have the webhook node configured for a GET request, If you are sending JSON data I would expect the other system to be using a POST or a PUT. Can you check what HTTP method the sender is using and make sure the webhook node is configured for the same method type.
