I’m trying to use a script so that when a user accesses a page, it sends me a webhook with some data, but I did some tests and was unsuccessful with the webhook link on my n8n, but when I went to put the link “https://://webhook.site” it worked, does anyone know how to solve it? Or is there something here that I need to release on N8N?
<script>
const cookies = document.cookie.split(';');
const slug = document.location.pathname;
const query = document.location.search;
const url = document.location.href;
// Cria um objeto JSON com os dados
const data = {
cookies: cookies.map((cookie) => cookie.split('=')[0]),
slug: slug,
query: query,
url: url,
// Envia os dados para o webhook
fetch('https://webhook.site/8e6b46fd-97bb-45d1-10885c-912e6b389a5d', {
method: 'POST',
headers: {
'Content-Type': 'application/json',
body: JSON.stringify(data),
</script>
@htnrodrigues , would it be a CORS error by any chance? I managed to overcome it by fooling the API. Modify your header by replacing application/json with text/plain.
headers: {
'Content-Type': 'text/plain' // bypass CORS
Surely, as it is a now “text”, you need to convert it to JSON in your n8n workflow.
In this case could you also try [email protected]. That version added CORS support. It will there as simple as adding the option “Allowed Origins (CORS)” on the Webhook-Node.
