Webhook return 504 gateway timeout
I installed n8n on my computer using npm.then I tested the GET url of the webhook. I got the error “504 Gateway Time-out” and I stopped n8n and restarted it with the command “npx n8n start --tunnel” from the terminal but still the same problem persists.
  • **n8n version:1.74.3
  • Database :default: SQLite
  • **Running n8n via npm
  • **Operating system:windows 11 home
