Webhook return TIMEOUT when using --tunnel
I created a new local installation of n8n on macOS and ran n8n start --tunnel to use the webhook with HTTPS. Although the command executes successfully, when trying to make a test request to the webhook, the connection fails, resulting in a timeout. Without using HTTPS, it works normally.
Has anyone experienced this before and have any ideas on how to solve it?
Hey @Rafael_Nogueira,
Welcome to the community :cake:
I would advise against using the tunnel at the moment as we will be removing it soon, If you wanted to continue using a tunnel based approach I would recommend using Cloudflare Tunnels or NGROK.
Hi Jon,
Curious to understand which mechanism will replace --tunnel ?
Stéphane
Hi, thanks for all your help. I was able to solve the issue by using NGROK. I came across the solution elsewhere, and it worked perfectly.
It might be helpful to update the documentation to mention that using the --tunnel option is no longer recommended. This could save others from encountering the same issue.
