Webhook stuck
Hello community.
Until 5 days ago my webhook worked without problems.
Overnight, it stopped working and now it only works when I receive the webhook as “test”.
My n8n is hosted on railway.app. Do you know what I can do to solve it?
Webhook stuck in “running”.
“meta”: {
“instanceId”: “53d723ac82d2abae6c9cfa6119bfed969616d6942c77bd35bb326fdf177c82c3”
“nodes”: [
“parameters”: {
“httpMethod”: “POST”,
“path”: “74ad2708-20c8-48f3-ab15-8c4ea9618d28”,
“options”: {}
“id”: “f14b19e7-8ce7-4bf6-bc8c-26787744d91c”,
“name”: “Webhook”,
“type”: “n8n-nodes-base.webhook”,
“typeVersion”: 1,
“position”: [
640,
340
“webhookId”: “74ad2708-20c8-48f3-ab15-8c4ea9618d28”
“parameters”: {
“phoneNumberId”: “1323133”,
“recipientPhoneNumber”: “=555199636536”,
“template”: “linchpin_ao_vivo2|pt_BR”,
“components”: {
“component”: [
“type”: “header”,
“headerParameters”: {
“parameter”: [
“type”: “image”,
“imageLink”: “={{ $json.body[‘contact[first_name]’] }}”
“type”: “button”,
“sub_type”: “url”,
“buttonParameters”: {
“parameter”: {
“type”: “text”,
“text”: “={{ $json.body[‘contact[fields][15512_live_room_join_link]’] }}”
“bodyParameters”: {
“parameter”: [
“text”: "={{ $json.body[‘contact[first_name]’] }}, a MasterClass "Email Milionário" que você se registrou está começando AGORA. "
“id”: “49b3511e-07a3-4c3a-9c74-f195dd2eb8b3”,
“name”: “WhatsApp - Estamos Ao Vivo”,
“type”: “n8n-nodes-base.whatsApp”,
“typeVersion”: 1,
“position”: [
800,
340
“retryOnFail”: false,
“waitBetweenTries”: 5000,
“maxTries”: 5,
“credentials”: {
“whatsAppApi”: {
“id”: “2IYgknSvRko6OaEl”,
“name”: “WhatsApp account”
“connections”: {
“Webhook”: {
“main”: [
“node”: “WhatsApp - Estamos Ao Vivo”,
“type”: “main”,
“index”: 0
n8n versions: 1.14.2
Database: Postgres
Running n8n via: Railway
Hi @laschuk, I am sorry you are having trouble. I am not sure if this is related to the webhook or rather a problem with your n8n workflow execution caused by a subsequent node.
Which response are you getting when calling your webhook’s production URL? Anything interesting in your n8n server logs?
And are you also seeing this behaviour on the most recent version of n8n 1.25.0?
