Webhook works in test but not in Production
Hi,
I am seeing that webhook works fine when testing (POST webhook), but it does not in Production.
I noticed I have not defined the Webhook tunnel, so could this be the issue or should I look for something else?
Thank you very much.
Are you activating the workflow? If so, make sure you are copying the URL when the tab is production. Also, your URL should not be localhost. If your says localhost, then you have to set the env variable WEBHOOK_TUNNEL_URL.
Hi @RicardoE105,
Yes I am activating :slight_smile:. My configuration is as per the documentation:
Folder where data should be saved
DATA_FOLDER=/root/n8n/
The top level domain to serve from
DOMAIN_NAME=XXXX
The subdomain to serve from
SUBDOMAIN=n8n
DOMAIN_NAME and SUBDOMAIN combined decide where n8n will be reachable from
above example would result in: https://n8n.example.com
The user name to use for autentication - IMPORTANT ALWAYS CHANGE!
N8N_BASIC_AUTH_USER=XXXXX
The password to use for autentication - IMPORTANT ALWAYS CHANGE!
N8N_BASIC_AUTH_PASSWORD=XXXXXX
Optional timezone to set which gets used by Cron-Node by default
If not set New York time will be used
GENERIC_TIMEZONE=Europe/Berlin
The email address to use for the SSL certificate creation
SSL_EMAIL=XXXXX
Thank you.
Best,
Jorge
I am getting the same error. how is it fixed?
