i am not able to receive any data from contact form 7 using webhooks. the Webhooks is not getting triggered. i am not able to receive any data from the form submission using the test link
Hi @Santhosh_Raaj, I am very sorry you are having trouble.
Is there a chance you are using the production URL instead of the test URL shown on your screenshot? Requests sent to your production URL will not appear on your canvas immediately. Instead, they will execute in the background and you can review the results in your executions list.
Also, can you confirm that GET is the right HTTP method? n8n defaults to GET, but many other services use POST by default.
If neither of the points above apply in your case, can you confirm the exact response you are seeing when calling your webhook URL?
