Websockets and SSE connection lost
I get connection lost or connection error on scenario view or testing webhook
console output
WebSocket connection to 'wss://n8n.cybershu.eu/rest/push?sessionId=gxaop3s3uuj' failed:
I use docker-compose + nginx:
docker-compose
version: '3.1'
services:
  n8n:
    image: docker.n8n.io/n8nio/n8n
    restart: always
    ports:
      - "5678:5678"
    environment:
      - N8N_BASIC_AUTH_ACTIVE=true
      - N8N_BASIC_AUTH_USER=usr
      - N8N_BASIC_AUTH_PASSWORD=any_pass
      - N8N_HOST=n8n.cybershu.eu
      - N8N_PORT=5678
      - N8N_PUSH_BACKEND=websocket
      - N8N_PROTOCOL=https
      - WEBHOOK_URL=https://n8n.cybershu.eu/
      - VUE_APP_URL_BASE_API=https://n8n.cybershu.eu/
    volumes:
      - /var/run/docker.sock:/var/run/docker.sock
      - ./n8n:/home/node/.n8n
    command: "n8n start --tunnel"
nginx config
server {
    server_name n8n.cybershu.eu;
    location / {
        proxy_pass http://127.0.0.1:5678;
        proxy_buffering off;
        proxy_cache off;
        chunked_transfer_encoding off;
        proxy_set_header Host $host;
        proxy_set_header X-Real-IP $remote_addr;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto $scheme;
        proxy_http_version 1.1;
        proxy_set_header Connection "upgrade";
        proxy_read_timeout 86400;
    location /rest/push {
	proxy_pass http://127.0.0.1:5678/rest/push;
	proxy_redirect off;
    listen 443 ssl; # managed by Certbot
    listen [::]:443 ssl;
    ssl_certificate /etc/letsencrypt/live/n8n.cybershu.eu/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/n8n.cybershu.eu/privkey.pem; # managed by Certbot
    include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
    ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
server {
    if ($host = n8n.cybershu.eu) {
        return 301 https://$host$request_uri;
    } # managed by Certbot
    listen 80;
    return 404; # managed by Certbot
I run uwsc ws://127.0.0.1:5678/rest/push but connection failed.
  • n8n version: newest
  • Running n8n via (Docker, npm, n8n cloud, desktop app): docker + nginx as reversed proxy
  • Operating system: ubuntu
Hi @michmzr, I am sorry you’re having trouble. Is your n8n instance running as it should? Any errors in the server logs?
And can you clarify if you’re seeing the same behaviour without the tunnel command (seeing you are already using your own domain n8n.cybershu.eu there should be no need for the tunnel)?
yes, instance is running.
There is no warning or errors in dockers compose logs
n8n_1  | License manager not initialized
n8n_1  | Last session crashed
n8n_1  | n8n ready on 0.0.0.0, port 5678
n8n_1  | Initializing n8n process
I commented command with --tunnel, connection with websocket is still failing. I checked it on Brave, Safari and Chrome.
Hm, tbh I am not fully sure which impact the separate location directive for /rest/push has as I haven’t used nginx for quite a while. Are you also seeing problems when removing this directive temporarily?
Is the connection working without a reverse proxy (for example when testing an ssh tunnel)?
Any chance there are additional components sitting between your browser and n8n (something like Cloudflare perhaps)?
No change
No working
I removed config from Nginx and its started working, but without TLS and https
Hm, that’s strange and you might want to review your nginx config with the nginx community to be sure. It would however confirm this isn’t an n8n-specific problem but one on the reverse proxy level.
Based on my understanding there is no need for the additional location /rest/push directive to achieve a TLS/https connection from your browser. As a reference point, this (plus the certbot section added later) was my own nginx config when I was still using this web server.
@mutantx
location /rest/push was recommended by ChatGPT :wink:
Your config from GitHub - that-one-tom/n8n-on-oracle-vm: A step by step description of setting up n8n using Ubuntu, Docker, NGINX + UFW on an Oracle Cloud VM · GitHub helped :pink_heart:
My current config:
docker compose
version: '3.1'
services:
  n8n:
    restart: unless-stopped
    container_name: n8n
    ports:
      - "5678:5678"
    environment:
      - N8N_BASIC_AUTH_USER=...
      - N8N_BASIC_AUTH_PASSWORD=...
      - N8N_HOST=[server ip address]
      - N8N_PORT=5678
      - WEBHOOK_URL=https://my.sub.domain/
    volumes:
nginx config file
  GNU nano 4.8                                     /etc/nginx/sites-available/n8n.cybershu.eu
server {
    server_name [domain]; # domain like sub.example.com
    location / {
        proxy_pass http://127.0.0.1:5678; # ip address and port of dockerized n8n
        proxy_set_header Connection '';
        proxy_cache off;
    ssl_certificate /etc/letsencrypt/live/[subdomain]/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/[subdomain]/privkey.pem; # managed by Certbot
server {
    if ($host = [subdomain]) {
    listen 80;
    server_name [subdomain];
Sweet, glad to hear this worked for you. Thanks a lot for confirming :slight_smile:
