Weekly AI Automation Tip
One useful n8n workflow for businesses is automated lead qualification.
A simple flow can be:
Customer enquiry → Webhook → AI analysis → Lead qualification → CRM/Google Sheets → Follow-up → Team notification
Instead of manually checking every enquiry, AI can analyse the message, identify the customer’s requirements, assign a lead status, and trigger the next action automatically.
Example:
New enquiry received
AI analyses the message
Qualified / Not qualified
Lead saved to CRM
Follow-up triggered
Sales team notified
Tip: Don’t try to automate the entire business at once. Start with one repetitive process, measure the result, and then expand the workflow.
I’m also sharing the workflow JSON so others can adapt it for their own projects.
[PASTE YOUR EXPORTED N8N WORKFLOW JSON HERE]
Important: Remove API keys, passwords, OAuth tokens and other credentials before sharing the JSON.
What part of your lead-generation process are you currently automating with n8n?
