I am trying to add to nodes_base folder and build docker image every time to use the node. npm run dev doesn’t start the service
Hi @Biprakanta_Pal,
welcome to the community
Did you follow our n8n docs? Like Creating Your First Node?
You have to execute the following in n8n’s root folder (not the packages/nodes_base folder).
# one time to init packages and dependencies
lerna bootstrap --hoist
npm run build
# while developing nodes
npm run dev
Does it work when executing in the root folder?
