Whatsapp trigger not working
Hello, I am trying to make a bot with whatsapp but as soon as I stopped using the test number it stopped working. Im not receiving any messages, and the number appears as offline in Meta.
The business is verified too
Hi @carlos_van_kurczyn
Test phone numbers provided by Meta for the WhatsApp Business API are intended for development purposes and come with limitations.
Test phone numbers allow you to send free messages for 90 days.
That’s probably the reason that the number appears as offline in Meta
Hey!
What I meant is that test number works perfectly. But as soon as I changed to a real number it is not working.
The number on meta platform appears as offline. And also on n8n I did make sure to change the business id
Hey.
I had a maybe similar issue. When I was working with the WhatsApp trigger node, the web-hook was only responding to the messages sent to the test number, so anything sent to the production number was being ignored.
I finally found out that you need to subscribe your production number to the WABA (WhatsApp Business Account) with:
curl -X POST \
  -H "Authorization: Bearer $TOKEN" \
  "https://graph.facebook.com/v22.0/$WABA_ID/subscribed_apps"
Where $WABA is your Whatsapp Business Account ID for the production number found in the app dashboard in the meta developers platform
Hey! thanks for the help. Im not a tech person so sorry if its this very dumb.
But where should I put that?
thanks in advance
Well, that should be sent to the meta API from whatever platform you are using, thats on their docs, it can be a terminal command, a python script or whatever, I personally use Postman.
https://developers.facebook.com/docs/graph-api
Did anyone find a solution to this? So far, the only one that works for me is triggering from Make (which works) and sending it to n8n, but would love to avoid doing this
thanks bro , work for me
