Whatsapp trigger Problem
I’m trying to connect to WhatsApp using n8n self-host. I added the tunnel function, but the endpoint is not working, even though I ping it and gives me success connection
Problem running workflow
Show Details
WhatsApp Trigger: (#2200) Callback verification failed with the following errors: curl_errno = 28; curl_error = Operation timed out after 5999 milliseconds with 0 bytes received; HTTP Status Code = 200; HTTP Message = Connection established
“nodes”: [
“parameters”: {
“updates”: [
“messages”
“options”: {}
“type”: “n8n-nodes-base.whatsAppTrigger”,
“typeVersion”: 1,
“position”: [
0,
0
“id”: “f1002d63-b2be-41be-adfa-9c85c9785ad6”,
“name”: “WhatsApp Trigger”,
“webhookId”: “88181b92-30d0-4f59-a6ac-1500b6b5c919”,
“credentials”: {
“whatsAppTriggerApi”: {
“id”: “lubLBB2zh5MT1uNz”,
“name”: “WhatsApp OAuth account”
“connections”: {},
“pinData”: {},
“meta”: {
“instanceId”: “de631ac8454cb381c20feb7f02f4770b16a445031cf4959b58e5657cc5e95e56”
WhatsApp Trigger: (#2200) Callback verification failed with the following errors: curl_errno = 28; curl_error = Operation timed out after 6000 milliseconds with 0 bytes received; HTTP Status Code = 200; HTTP Message = Connection established
  • n8n version: 1.84.3
  • n8n EXECUTIONS_PROCESS setting (default:)
  • Running n8n via (Docker)
  • Operating system: Mac OS M1
Are you able to make it work without the tunnel?
nop, it doesn’t work without it either
It might be an issue with your credentials, then.
Can you please watch this tutorial and see if you’ve missed something?
You can also check the official documentation:
Where you able to solve this? having the same issue
