Where does n8n cli save exported workflows for docker?
I have n8n running on Docker and had exported the workflows using this command. The challenge is that I can not find the workflows/directory to which they are exported. How can I find them?
I tried using this command to run n8n with a local folder but couldnt read local files from the docker container. How can I solve this?
docker run -it --rm --name n8n1 -p 5678:5678 -v /home/n8n-files:/n8n-files -v n8n_data:/home/node/.n8n docker.n8n.io/n8nio/n8n
hello @Imperol
have you checked the /home/node/.n8n/backups/latest folder of the container?
