I’ve set up a workflow that will create a CSV and then upload the file to a vendor through SFTP. The challenge is the vendor requires the sender IP address to be whitelisted.
I’m using n8n Cloud and when I asked the AI Assistant, it gave me 22 IPs to whitelist with a warning they can change at any time. Is there any way set a static IP or at least reduce it to only a few?
n8n Cloud runs on dynamic infrastructure, and its IP addresses can and do change, which is why you were given a full IP range. Unfortunately, there’s no way to guarantee a static outbound IP from n8n Cloud today.
Options to Solve This:
1. Use Self-Hosted n8n
Host n8n yourself (e.g., on a VPS or in Docker), and then:
You control the public IP.
You can whitelist your server’s IP with the vendor.
Great for SFTP, VPNs, and external services needing static IPs.
2. Use a Proxy Server or Static IP Gateway
If you want to stay on n8n Cloud:
Set up a small server (e.g., DigitalOcean droplet) with a static IP.
Use SSH tunneling or a SOCKS5/HTTP proxy from n8n to that server.
Let the server connect to the vendor’s SFTP — this keeps the n8n Cloud’s IP out of the picture.
3. Use n8n Cloud + External SFTP Microservice
Build a lightweight function (Node.js, Python, etc.) hosted on a static-IP service (e.g., Vercel, AWS Lambda behind NAT gateway).
Send the file from n8n to that service via HTTP.
Let that service upload it via SFTP.
Summary
No static IPs on n8n Cloud.
Self-hosting or proxying through a static IP is required for strict SFTP whitelisting.
For reliable long-term automation with static IP needs, consider running n8n yourself or routing the upload through a known IP server.
