Why does my workflow keep repeating?
self hosted set up here. I can’t figure out why this is repeating. it completes and everything works perfect and I check the executions and it has run 40 times in 5 minutes. over and over
  "meta": {
    "instanceId": "32661e4be5fdf7b33ada1a81089c57c1c62780434c5f9270e23ac9b71180fa02"
  "nodes": [
      "parameters": {
        "method": "PUT",
        "url": "=https://www.zohoapis.com/crm/v6/Property/{{ $('Webhook').first().json.query.id }}",
        "authentication": "predefinedCredentialType",
        "nodeCredentialType": "zohoOAuth2Api",
        "sendQuery": true,
        "queryParameters": {
          "parameters": [
        "sendBody": true,
        "bodyParameters": {
          "parameters": [
              "name": "data",
              "value": "={{ $json.data }}"
        "options": {
          "response": {
            "response": {
              "fullResponse": true,
              "responseFormat": "json"
      "id": "3ac2b01d-60e8-45f1-9301-1a8d2e194965",
      "name": "Add Property CRM",
      "typeVersion": 4.1,
      "position": [
        1060,
        -340
      "executeOnce": true,
      "credentials": {
        "zohoOAuth2Api": {
          "id": "6WcZrYGR3bVX34Ft",
          "name": "Zoho account"
      "parameters": {
        "path": "32f2d7bb-7b5b-459e-8430-daccf58cea91",
        "options": {
          "responseData": "success"
      "id": "f16f8e34-047c-4a54-8a5e-9b3bd52f268b",
      "name": "Webhook",
      "type": "n8n-nodes-base.webhook",
      "typeVersion": 1.1,
      "position": [
        -1060,
        -300
      "webhookId": "32f2d7bb-7b5b-459e-8430-daccf58cea91"
      "parameters": {
        "url": "https://unofficial-redfin.p.rapidapi.com/auto-complete",
        "sendQuery": true,
          "parameters": [
              "name": "location",
              "value": "={{ $('Webhook').item.json.query.street }} {{ $('Webhook').item.json.query.city }} {{ $('Webhook').item.json.query.state }} {{ $('Webhook').item.json.query.zip }}"
              "name": "limit",
              "value": "10"
        "sendHeaders": true,
        "headerParameters": {
          "parameters": [
              "name": "X-RapidAPI-Key",
              "value": "XX"
              "name": "X-RapidAPI-Host",
              "value": "unofficial-redfin.p.rapidapi.com"
        "options": {}
      "id": "3b69f7a0-4679-4981-9ceb-fa007bdb2886",
      "name": "Redfin Get Prop ID",
      "typeVersion": 4.1,
      "position": [
        -580,
        100
      "parameters": {
        "url": "https://redfin-com-data.p.rapidapi.com/property/detail",
        "sendQuery": true,
          "parameters": [
              "name": "url",
              "value": "={{ $json.payload.exactMatch.urlV2 }}"
          "parameters": [
              "value": "XX"
              "value": "redfin-com-data.p.rapidapi.com"
        "options": {
          "response": {
            "response": {
      "id": "97945c13-855a-4de4-9426-eefe4ee0abf0",
      "name": "Redfin Get Main Info",
      "typeVersion": 4.1,
      "position": [
        -360,
        100
      "parameters": {
        "fields": {
          "values": [
              "name": "DOM",
              "stringValue": "={{ $json.body.data.aboveTheFold.addressSectionInfo.cumulativeDaysOnMarket }}"
        "include": "selected",
        "options": {}
      "id": "12f30abf-ad7e-4aa3-a93d-ba02c2366b40",
      "name": "Redfin Main Info Fields",
      "type": "n8n-nodes-base.set",
      "typeVersion": 3.2,
      "position": [
        80,
        120
      "parameters": {
        "mode": "combine",
        "combinationMode": "mergeByPosition",
        "options": {}
      "id": "5ba7e9f1-4720-4e1b-b3bc-847af7704edf",
      "name": "Merge",
      "type": "n8n-nodes-base.merge",
      "typeVersion": 2.1,
      "position": [
        320,
        -120
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "820a699d-33e1-4e55-8cc2-c7a0a64c87f6",
      "name": "Merge1",
      "typeVersion": 2.1,
      "position": [
        520,
        -680
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "e81675c0-7225-4f57-a9b3-da3229630ea1",
      "name": "Merge2",
      "typeVersion": 2.1,
      "position": [
        540,
        40
      "parameters": {
        "aggregate": "aggregateAllItemData",
        "options": {}
      "id": "b35a6af4-d776-425d-a02f-a25e7cf6aaf2",
      "name": "Aggregate1",
      "type": "n8n-nodes-base.aggregate",
      "typeVersion": 1,
      "position": [
        880,
        -340
      "parameters": {
        "url": "https://zillow-com1.p.rapidapi.com/locationSuggestions",
        "sendQuery": true,
          "parameters": [
              "name": "q",
          "parameters": [
              "value": "XX"
              "value": "zillow-com1.p.rapidapi.com"
        "options": {
          "response": {
            "response": {
      "id": "79f1f14e-21b4-454c-b7f1-80945bf3b4b1",
      "name": "Get ZPID",
      "typeVersion": 4.1,
      "position": [
        -740,
        -680
      "executeOnce": true
      "parameters": {
        "fields": {
          "values": [
              "name": "Realtor_Since",
              "stringValue": "={{ $json.about.yearsExperience }}"
        "options": {}
      "id": "4d047964-0a73-472b-8f66-bfa56391b1f9",
      "name": "Edit Fields2",
      "typeVersion": 3.2,
      "position": [
        80,
        -200
      "parameters": {
        "method": "POST",
        "url": "=https://www.zohoapis.com/crm/v6/Property/{{ $('Aggregate1').item.json.data[0].id }}/photo",
        "sendBody": true,
        "contentType": "multipart-form-data",
        "bodyParameters": {
          "parameters": [
              "parameterType": "formBinaryData",
              "name": "file",
              "inputDataFieldName": "file"
        "options": {
          "response": {
            "response": {
      "id": "83d46ab9-eda4-4d2e-b251-3e4149ac4cdc",
      "name": "HTTP Request",
      "typeVersion": 4.1,
      "position": [
        1420,
        -340
      "credentials": {
        "zohoOAuth2Api": {
      "parameters": {
        "url": "https://zillow-com1.p.rapidapi.com/property",
        "sendQuery": true,
          "parameters": [
              "name": "zpid",
              "value": "={{ $json.ZPID }}"
          "parameters": [
              "value": "XX"
        "options": {
          "response": {
            "response": {
      "id": "a551acb4-28b3-412f-8035-b6d78a7c15e1",
      "name": "Get All Zillow Details",
      "typeVersion": 4.1,
      "position": [
        -460,
        -680
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "88ba94d5-5699-4c88-a203-7694b65ec08e",
      "name": "Merge5",
      "typeVersion": 2.1,
      "position": [
        320,
        -460
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "ce7b687c-5411-44d7-a4fd-bea13b16ce9d",
      "name": "Merge3",
      "typeVersion": 2.1,
      "position": [
        300,
        -780
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "a08f19ed-aefa-478f-a51b-55994a67c247",
      "name": "Merge4",
      "typeVersion": 2.1,
      "position": [
        320,
        180
      "parameters": {
        "fields": {
          "values": [
              "name": "Last_Updated",
              "stringValue": "={{ $json.Last_Updated }}"
        "options": {}
      "id": "6e9ea037-6810-4905-ba27-8d8e8f774164",
      "name": "Edit Fields4",
      "typeVersion": 3.2,
      "position": [
        80,
        -860
      "parameters": {
        "operation": "formatDate",
        "date": "={{ $json.body.attributionInfo.lastUpdated }}",
        "format": "custom",
        "customFormat": "yyyy-MM-dd'T'HH:mm:ss",
        "outputFieldName": "Last_Updated",
        "options": {}
      "id": "9358c4d9-04fc-4bdc-8ea4-0caed2539d21",
      "name": "Last Updated",
      "type": "n8n-nodes-base.dateTime",
      "typeVersion": 2,
      "position": [
        -160,
        -860
      "parameters": {
        "url": "={{ $('Aggregate1').item.json.data[0].propimg01 }}",
        "options": {
          "response": {
            "response": {
              "responseFormat": "file",
              "outputPropertyName": "file"
      "id": "9a7aa232-1d4a-4695-9109-568e9c39c86e",
      "name": "HTTP Request4",
      "typeVersion": 4.1,
      "position": [
        1240,
        -340
      "parameters": {
        "fields": {
          "values": [
              "name": "ZillowComp01",
              "stringValue": "=https://www.zillow.com{{ $json.comps[0].hdpUrl }}"
        "options": {}
      "id": "2d7bed70-605a-4752-b38c-3d14f06ab6a4",
      "name": "Edit Fields5",
      "typeVersion": 3.2,
      "position": [
        80,
        -380
      "parameters": {
        "mode": "combine",
        "options": {}
      "id": "03a0c947-b197-494d-8fb0-005d44d5ef05",
      "name": "Merge6",
      "typeVersion": 2.1,
      "position": [
        720,
        -340
      "parameters": {
        "fields": {
          "values": [
              "name": "Status",
              "stringValue": "={{ $json.body.homeStatus }},  {{ $json.body.contingentListingType }}"
        "options": {}
      "id": "6998cbe4-5549-4e83-afef-170dd5cb376a",
      "name": "Edit Fields6",
      "typeVersion": 3.2,
      "position": [
        80,
        -700
      "parameters": {
        "url": "https://zillow-com1.p.rapidapi.com/propertyComps",
        "sendQuery": true,
          "parameters": [
              "name": "zpid",
              "value": "={{ $json.body.zpid }}"
          "parameters": [
              "value": "XX"
        "options": {}
      "id": "c3f431e7-c88e-4232-9c36-f3e26c1ead85",
      "name": "Get Zillow Comps",
      "typeVersion": 4.1,
      "position": [
        -460,
        -500
      "parameters": {
        "fields": {
          "values": [
              "name": "ZPID",
              "stringValue": "={{ $json.body.results[0].metaData.zpid }}"
        "options": {}
      "id": "3cd24271-a3ee-4cad-a668-1d015356c490",
      "name": "Edit Fields7",
      "typeVersion": 3.2,
      "position": [
        -600,
        -680
      "parameters": {
        "fields": {
          "values": [
              "name": "zpid",
              "stringValue": "={{ $json.body.zpid }}"
        "options": {
          "ignoreConversionErrors": true
      "id": "15ef61ae-c880-4e85-8992-ef73f12c2a16",
      "name": "Edit Fields3",
      "typeVersion": 3.2,
      "position": [
        80,
        -540
      "parameters": {
        "url": "https://zillow-com1.p.rapidapi.com/images",
        "sendQuery": true,
          "parameters": [
              "name": "zpid",
              "value": "={{ $('Get All Zillow Details').first().json.body.zpid }}"
          "parameters": [
              "value": "XX"
        "options": {}
      "id": "e7c728c6-fc09-4ede-8d07-9db05a982d55",
      "name": "Get Property Images",
      "typeVersion": 4.1,
      "position": [
        -460,
        -140
      "parameters": {
        "fields": {
          "values": [
              "name": "propimg01",
              "stringValue": "={{ $json.images[0] }}"
        "options": {}
      "id": "b759236d-31fc-40bf-929d-da46dc3d15fa",
      "name": "Edit Fields8",
      "typeVersion": 3.2,
      "position": [
        80,
        -40
      "parameters": {
        "url": "https://realtor.p.rapidapi.com/properties/v3/detail",
        "sendQuery": true,
          "parameters": [
              "name": "property_id",
              "value": "={{ $json.autocomplete[0].mpr_id }}"
          "parameters": [
              "value": "XX"
              "value": "realtor.p.rapidapi.com"
        "options": {}
      "id": "aaf640a3-a592-4619-916d-a0676da929c4",
      "name": "HTTP Request2",
      "typeVersion": 4.1,
      "position": [
        -360,
        360
      "parameters": {
        "url": "https://realtor.p.rapidapi.com/locations/v2/auto-complete",
        "sendQuery": true,
          "parameters": [
              "name": "input",
              "value": "={{ $('Get All Zillow Details').item.json.body.address.streetAddress }} {{ $('Get All Zillow Details').item.json.body.address.city }} {{ $('Get All Zillow Details').item.json.body.address.state }} {{ $('Get All Zillow Details').item.json.body.address.zipcode }}"
          "parameters": [
              "value": "XX"
        "options": {}
      "id": "d0d77c59-7f73-4053-a1a3-57fba1e11571",
      "name": "HTTP Request3",
      "typeVersion": 4.1,
      "position": [
        -580,
        360
      "parameters": {
        "fields": {
          "values": [
              "name": "Collateral_Analytics",
              "stringValue": "={{ $json.data.home.estimates.current_values[1].estimate }}"
        "options": {}
      "id": "7f95c379-0fee-4ceb-9456-a2c44e6df926",
      "name": "Edit Fields9",
      "typeVersion": 3.2,
      "position": [
        80,
        280
      "parameters": {
        "url": "https://zillow-com1.p.rapidapi.com/agentDetails",
        "sendQuery": true,
          "parameters": [
              "name": "username",
              "value": "={{ $('Get All Zillow Details').item.json.body.listed_by.profile_url.slice(31,-1) }}"
          "parameters": [
              "value": "XX"
        "sendBody": true,
        "bodyParameters": {
          "parameters": [
        "options": {}
      "id": "fcd638c8-3c1f-4b2a-aff2-e0df5915eb32",
      "name": "get agent details",
      "typeVersion": 4.1,
      "position": [
        -460,
        -320
      "alwaysOutputData": true,
      "onError": "continueRegularOutput"
      "parameters": {},
      "id": "1f8891c3-b207-463f-b201-0ac7a3b62e99",
      "name": "DONE",
      "type": "n8n-nodes-base.noOp",
      "typeVersion": 1,
      "position": [
        1580,
        -340
  "connections": {
    "Add Property CRM": {
      "main": [
            "node": "HTTP Request4",
            "type": "main",
            "index": 0
    "Webhook": {
      "main": [
            "node": "Get ZPID",
            "type": "main",
            "index": 0
    "Redfin Get Prop ID": {
      "main": [
            "node": "Redfin Get Main Info",
            "type": "main",
            "index": 0
    "Redfin Get Main Info": {
      "main": [
            "node": "Redfin Main Info Fields",
            "type": "main",
            "index": 0
            "node": "HTTP Request3",
            "type": "main",
            "index": 0
    "Redfin Main Info Fields": {
      "main": [
            "node": "Merge4",
            "type": "main",
            "index": 0
    "Merge": {
      "main": [
            "node": "Merge2",
            "type": "main",
            "index": 0
    "Merge1": {
      "main": [
            "node": "Merge6",
            "type": "main",
            "index": 0
    "Merge2": {
      "main": [
            "node": "Merge6",
            "type": "main",
            "index": 1
    "Aggregate1": {
      "main": [
            "node": "Add Property CRM",
            "type": "main",
            "index": 0
    "Get ZPID": {
      "main": [
            "node": "Edit Fields7",
            "type": "main",
            "index": 0
    "Edit Fields2": {
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 0
    "HTTP Request": {
      "main": [
            "node": "DONE",
            "type": "main",
            "index": 0
    "Get All Zillow Details": {
      "main": [
            "node": "Get Zillow Comps",
            "type": "main",
            "index": 0
    "Merge5": {
      "main": [
            "node": "Merge1",
            "type": "main",
            "index": 1
    "Merge3": {
      "main": [
            "node": "Merge1",
            "type": "main",
            "index": 0
    "Merge4": {
      "main": [
            "node": "Merge2",
            "type": "main",
            "index": 1
    "Edit Fields4": {
      "main": [
            "node": "Merge3",
            "type": "main",
            "index": 0
    "Last Updated": {
      "main": [
            "node": "Edit Fields4",
            "type": "main",
            "index": 0
    "HTTP Request4": {
      "main": [
            "node": "HTTP Request",
            "type": "main",
            "index": 0
    "Edit Fields5": {
      "main": [
            "node": "Merge5",
            "type": "main",
            "index": 1
    "Merge6": {
      "main": [
            "node": "Aggregate1",
            "type": "main",
            "index": 0
    "Edit Fields6": {
      "main": [
            "node": "Merge3",
            "type": "main",
            "index": 1
    "Get Zillow Comps": {
      "main": [
            "node": "get agent details",
            "type": "main",
            "index": 0
            "node": "Edit Fields5",
            "type": "main",
            "index": 0
    "Edit Fields7": {
      "main": [
            "node": "Get All Zillow Details",
            "type": "main",
            "index": 0
    "Edit Fields3": {
      "main": [
            "node": "Merge5",
            "type": "main",
            "index": 0
    "Get Property Images": {
      "main": [
            "node": "Edit Fields8",
            "type": "main",
            "index": 0
            "node": "Redfin Get Prop ID",
            "type": "main",
            "index": 0
    "Edit Fields8": {
      "main": [
            "node": "Merge",
            "type": "main",
            "index": 1
    "HTTP Request2": {
      "main": [
            "node": "Edit Fields9",
            "type": "main",
            "index": 0
    "HTTP Request3": {
      "main": [
            "node": "HTTP Request2",
            "type": "main",
            "index": 0
    "Edit Fields9": {
      "main": [
            "node": "Merge4",
            "type": "main",
            "index": 1
    "get agent details": {
      "main": [
            "node": "Edit Fields2",
            "type": "main",
            "index": 0
            "node": "Get Property Images",
            "type": "main",
            "index": 0
  "pinData": {}
@djjace , do you mean 40 different executions with the same data?
Your workflow is triggered by the webhook. If the webhook does not respond with the expected response then the application that sent the data to your webhook might be thinking that the HTTP request did not reach its destination and keeps re-sending the same message again.
If that looks like what you are observing, check the documentation for the API of the service/app that sends HTTP request to your workflow. Perhaps replying with code 200 is not enough and it expects some specific text too confirming the receipt of the message.
