Why is my LLM node running continuously?
I am not sure but why is my anthropic node running continuously?
Below you can see I am pulling 803 rows. I clean up the rows to lower the tokens and then I pass it to my Basic LLM Chain to do 1 call to anthropic to analyze my sheet. I add the previous input using the {{ $input.all() }} using Define Below option, then I add a system and user prompt. However, I see this run 10 times like here and before it ran like 45 times.
My node is running continously
  • n8n version: 1.94.1
  • Operating system: MacOS
hi - what is your prompt in the LLM.
I have just tried this and as you can see it runs all once for each row (17 rows all the way), i did a simple check if the column is a string or number, and I have output this value out for you too for further processing. You have to map your JSON in the structured output parser.
Ensure your prompt has the right logic, I am sharing this with you too.
One question here:
Do you want LLM to run once or 803 times
If you only want to run once
Here is the example
You can use aggregate to make multiple items into one.
And in LLM user prompt use
{{ $json.holder_name.join() }}
To join the array. or toJsonString()
