Woocommerce order.updated triger not working
I create woocommerce order updated triger.
Why when I manually change order status from on hold to complete in woocommerce order menu, the triger not working. What should I do to solved this problem
Hi, please start by sharing your configuration. workflow. type of hosting. etc
reg,
J.
solved. I try this morning, it works
Great, can you please solve your own question? Thanks
Reg
J.
