Woocommerce trigger order created not appear in execution and not start the workflow
Hi Woocommerce trigger order created not appear in execution and not start the workflow, woocommerce sent the webhook, n8n respond with 200 but not appear in the execution and not trigger the workflow.
The strange thing if i create an order as administrator the order created trigger works normally but from other users not!
is possible something related to cloudflare ? Need Help..
2025-11-26T09:34:02+00:00 Info Array
    [Webhook Delivery] => Array
            [Delivery ID] => cb7817fd7b0090c2fdee6f2bab70341a
            [Date] => Nov 26, 2025 @ 9:34
            [URL] => https://n8n-wsosw48coks0cwww4c8gc4s8.autom.rewamp.it/webhook/85c49d0c-2ef0-49ba-a1e0-dfca69497983/webhook
            [Duration] => 0.11627
            [Request] => Array
                    [Method] => POST
                    [Headers] => Array
                            [User-Agent] => WooCommerce/10.3.5 Hookshot (WordPress/6.8.3)
                            [Content-Type] => application/json
                            [X-WC-Webhook-Source] => https://colosso.org/
                            [X-WC-Webhook-Topic] => order.created
                            [X-WC-Webhook-Resource] => order
                            [X-WC-Webhook-Event] => created
                            [X-WC-Webhook-Signature] => JbduWdVX9Pkohwc/UdNd9EZfiXc2AdJBq+sEdYqXBk4=
                            [X-WC-Webhook-ID] => 84
                            [X-WC-Webhook-Delivery-ID] => cb7817fd7b0090c2fdee6f2bab70341a
            [Body] => Webhook body is not logged unless WP_DEBUG mode is turned on. This is to avoid the storing of personal data in the logs.
            [Response] => Array
                    [Code] => 200
                    [Message] => OK
                    [Headers] => WpOrg\Requests\Utility\CaseInsensitiveDictionary Object
                            [data:protected] => Array
                                    [date] => Wed, 26 Nov 2025 09:34:02 GMT
                                    [content-type] => text/html; charset=utf-8
                                    [alt-svc] => h3=":443"; ma=86400
                                    [etag] => W/"e-gKmlDAP62/I/ysztVW3SJGW7K+0"
                                    [vary] => Array
                                            [0] => Accept-Encoding
                                            [1] => Accept-Encoding
                                    [cf-cache-status] => DYNAMIC
                                    [nel] => {"report_to":"cf-nel","success_fraction":0.0,"max_age":604800}
                                    [report-to] => {"group":"cf-nel","max_age":604800,"endpoints":[{"url":"https://a.nel.cloudflare.com/report/v4?s=MK38zlhWlRH4bLvfl%2F08l19pl0zVK9%2BzGF8Pm%2FRKYuR5hZtOyipRhCcHr1fTw%2BF%2F8kdRIygNhQHHjn3nuR2oZ7vDqmuA2fzjZAMF6JPcgE0va6jsDePvpLmIiMvyne9UeYlJz2N7jMO2PVnB"}]}
                                    [content-encoding] => zstd
                                    [server] => cloudflare
                                    [cf-ray] => 9a4863430bf49171-FRA
2025-11-26T10:48:44+00:00 Info Array
            [Delivery ID] => a6d06602b00877575110cdd6dff13f38
            [Date] => Nov 26, 2025 @ 10:48
            [Duration] => 1.75115
            [Request] => Array
                    [Method] => POST
                    [Headers] => Array
                            [X-WC-Webhook-Signature] => 7E6uibF4vXBs0ay1toxp1xx6OFdKG8BgCdzqMmCEJMs=
                            [X-WC-Webhook-Delivery-ID] => a6d06602b00877575110cdd6dff13f38
            [Response] => Array
                    [Code] => 200
                    [Message] => OK
                                    [date] => Wed, 26 Nov 2025 10:48:44 GMT
                                    [content-type] => application/json; charset=utf-8
                                    [etag] => W/"23-NtpDzMsUcnBm9d5fplxPmZoZiD4"
                                    [vary] => Array
                                    [report-to] => {"group":"cf-nel","max_age":604800,"endpoints":[{"url":"https://a.nel.cloudflare.com/report/v4?s=MAwQgBaB1LmMRbbWY5GOwk9jagGxwwY%2F9tkebQU06BsVno%2BymOiVS7oRIGw2vr94BVF%2FRw2DHkVxM4w%2Ft0n3T3TQNPNR5mcMRys15UBn8U0rK2KENyFtnkQUHTNrkvdtVuJ2teJiOO8hDGMc"}]}
                                    [cf-ray] => 9a48d0adde66bb3e-FRA
this 2 coming but not the others
