I can’t connect my wordpress website. I’m getting an error whenever I enter the credentials:
Service Temporarily Unavailable
Any ideas why? Credentials are correct, URL is correct, although it is redirecting, as default WP behaviour wp-admin > wp-login… not sure if that has any bearing?
Edit with details:
Version: 1.73.1
Default databse
running n8n in browser
I’m new here so I haven’t changed any settings.
<your workflow>
Welcome to the community. We have replied in the Help Center. For clarity of the issue for everyone else’s sake you are hosting the WorpPress website on HostGator on your own domain. You do use application password bu the connection times out.
Our advise as the troublshooting step it to try connecting using Wordpress API, OAuth2 Authentication – WordPress.com Developer Resources. If you cannot connect that way, that the issue is rather with the hosting provider, they might be blocking this kind of connection.
