I’m using the OpenAI and WordPress modules to tag and categorize posts. I can download the list of tags and categories from WordPress, and I can ask OpenAI to categorize the post.
When I use {{ $json.message.content }} to update the post I get the following error
The error you see on the side is to be expected if you are not using one of the pre-select options from the dropdown. This is probably something we should fix in the future as it is confusing.
Looking at how it works you will need to use the category id from an expression not the name, This would normally be a number.
