Workflow stopped after updating my n8n to V2 "Problem running workflow Unrecognized node type: n8n-nodes-base.executeCommand"
Hello everyone,
After updating n8n to V2, my workflows have stopped working. none of my Execute Nodes are now disabled, and I was using them to run my own local JavaScript files. Could anyone please help me figure out how to fix this?
I am using require("node-fetch") and require("fast-xml-parser") in my JS that is not supported in Code Node !
Hello, Bud!
To re‑enable the Execute Command node, you need to make sure it’s not excluded via the NODES_EXCLUDE environment variable.
If you previously blocked it using NODES_EXCLUDE, set the variable to an empty array and restart n8n. Or add this parameter to restart, in V2 comes default disable.
For example, in your docker-compose.yml:
environment:
  - NODES_EXCLUDE=[]
Hope this help.
Yes I can definitely help with this let connect
Hey @shahrooz_m !
Execute Command is disabled by default for security purposes!
n8n v2 blocks the Execute Command node unless you explicitly re‑enable it.
Cheers!
tl;dr
set the empty environment variable
NODES_EXCLUDE=
Can I also fix this securely, so that I can just enable what I need and not everything?
