I have a self hosted instance of n8n and the below very simple workflow. For some reason the “test workflow” button works as expected, but when I enable the workflow, the resulting executions never finish running.
I’m quite new to n8n, so I’d appreciate any advice on where to start debugging.
Nothing suspicious on stdout
/stderr
N/A
n8n version: 1.25.1
Database (default: SQLite): PostgreSQL
n8n EXECUTIONS_PROCESS setting (default: own, main): EXECUTIONS_MODE=queue
Running n8n via (Docker, npm, n8n cloud, desktop app): docker
Operating system: TrueNAS-SCALE-23.10.0.1 (Debian GNU/Linux 12)
2024-02-20 10:35:29.371213-08:002024-02-20T18:35:29.370Z | e[32minfoe[39m | e[32m - "My workflow" (ID: 73KqfNlOEPzxMfow)e[39m "{ file: 'ActiveWorkflowRunner.js', function: 'add' }"
2024-02-20 10:35:29.371515-08:002024-02-20T18:35:29.371Z | e[34mdebuge[39m | e[34mInitializing active workflow "My workflow" (ID: 73KqfNlOEPzxMfow) (startup)e[39m "{\n workflowName: 'My workflow',\n workflowId: '73KqfNlOEPzxMfow',\n file: 'ActiveWorkflowRunner.js',\n function: 'add'\n}"
2024-02-20 10:35:29.378034-08:002024-02-20T18:35:29.377Z | e[34mdebuge[39m | e[34mAdding triggers and pollers for workflow "My workflow" (ID: 73KqfNlOEPzxMfow)e[39m "{ file: 'ActiveWorkflowRunner.js', function: 'addTriggersAndPollers' }"
2024-02-20 10:35:29.381017-08:002024-02-20T18:35:29.380Z | e[36mverbosee[39m | e[36mWorkflow "My workflow" (ID: 73KqfNlOEPzxMfow) activatede[39m "{\n workflowId: '73KqfNlOEPzxMfow',\n workflowName: 'My workflow',\n file: 'ActiveWorkflowRunner.js',\n function: 'addTriggersAndPollers'\n}"
2024-02-20 10:35:36.394435-08:002024-02-20T18:35:36.394Z [Rudder] debug: in flush
2024-02-20 10:35:36.394507-08:002024-02-20T18:35:36.394Z [Rudder] debug: cancelling existing flushTimer...
2024-02-20 10:35:48.013493-08:002024-02-20T18:35:48.011Z | e[34mdebuge[39m | e[34mWait tracker querying database for waiting executionse[39m "{ file: 'WaitTracker.js', function: 'getWaitingExecutions' }"
2024-02-20 10:36:29.401422-08:002024-02-20T18:36:29.400Z | e[34mdebuge[39m | e[34mReceived trigger for workflow "My workflow"e[39m "{ file: 'ActiveWorkflowRunner.js', function: 'returnFunctions.emit' }"
2024-02-20 10:36:29.498151-08:00Started with job ID: 1 (Execution ID: 150)
2024-02-20 10:36:48.013534-08:002024-02-20T18:36:48.012Z | e[34mdebuge[39m | e[34mWait tracker querying database for waiting executionse[39m "{ file: 'WaitTracker.js', function: 'getWaitingExecutions' }"
2024-02-20 10:37:09.349978-08:002024-02-20T18:37:09.349Z | e[36mverbosee[39m | e[36mSuccessfully deactivated workflow "73KqfNlOEPzxMfow"e[39m "{\n workflowId: '73KqfNlOEPzxMfow',\n file: 'ActiveWorkflowRunner.js',\n function: 'remove'\n}"
2024-02-20 10:37:09.379366-08:002024-02-20T18:37:09.378Z [Rudder] debug: no existing flush timer, creating new one
2024-02-20 10:37:19.380777-08:002024-02-20T18:37:19.379Z [Rudder] debug: in flush
2024-02-20 10:37:19.381051-08:002024-02-20T18:37:19.380Z [Rudder] debug: cancelling existing flushTimer...
2024-02-20 10:37:48.014112-08:002024-02-20T18:37:48.013Z | e[34mdebuge[39m | e[34mWait tracker querying database for waiting executionse[39m "{ file: 'WaitTracker.js', function: 'getWaitingExecutions' }"
2024-02-20 10:38:48.015209-08:002024-02-20T18:38:48.014Z | e[34mdebuge[39m | e[34mWait tracker querying database for waiting executionse[39m "{ file: 'WaitTracker.js', function: 'getWaitingExecutions' }"
Turned on debug logging and here is the log (execution 150
never finished).
Hi @yichi-yang What you’re describing sounds like a problem with your workers - text executions are run on the main instance, but production executions are sent over to the workers instead.
Do you have your workers up and running, and can they communicate with both Redis and your database?
You are right! I’m using the helm chart maintained by the TrueNAS community. It seems like it never starts the worker processes. I’ll file a bug report there.
system
Closed
March 1, 2024, 8:04am
5
