Workflows, credentials and execution data lost
I’m experiencing a critical data loss issue with my n8n installation where workflows and their execution history aswell as credentials have mysteriously disappeared from the database over a specific time period.
Environment
  • n8n version: 1.120.3 (happened on older version)
  • Installation type: Docker
  • Database: SQLite
  • Database location: /var/lib/docker/volumes/n8n_data/_data/database.sqlite
  • OS: Ubuntu
  • VPS Provider: Hostinger
What Happened
  1. Missing Data Period: Workflows and credentials created during a specific period of several weeks have completely disappeared
  2. Older Workflows Intact: Workflows created before this period are still present and working fine
  3. Execution History Lost: The execution history for the missing workflows is also gone
  4. Not Related to Update: Initially suspected an n8n update, but after restoring a backup from before the update, the workflows were already missing in that backup too
Database Investigation
Using DBeaver to connect to the SQLite database, I confirmed:
  • The workflow_entity table shows a clear gap in the createdAt dates
  • The execution_entity table is missing corresponding execution records
  • No soft-delete flags or similar indicators that would suggest recoverable data
  • The database file itself shows no obvious corruption
What I’ve Tried
  1. :white_check_mark: Checked multiple backup points - workflows already missing in all of them
  2. :white_check_mark: Verified database integrity - no corruption detected
  3. :white_check_mark: Confirmed no accidental manual deletion (no one else has access)
Questions
  1. Has anyone experienced similar data loss with SQLite-based n8n installations?
  2. Are there known issues with SQLite data integrity under specific conditions?
  3. Could this be related to:
    • Docker volume mounting issues?
    • SQLite WAL (Write-Ahead Logging) mode problems?
    • Disk space issues causing incomplete writes?
    • File system issues on the VPS?
  4. Is there any way to recover deleted rows from SQLite? (I still have access to the database file)
Additional Context
  • The missing workflows were under test and inactive, executing successfully before they disappeared
  • No disk space issues were present during the affected period
  • Server uptime was normal with no unexpected restarts
  • No backup system was configured at the time (now implementing automated backups)Request for Help
    Has anyone experienced something similar? Any suggestions on:
    • Potential root causes to investigate?
    • Recovery methods for SQLite databases?
    • Best practices to prevent this from happening again?
    • Should I migrate from SQLite to PostgreSQL for better reliability?
    Any insights would be greatly appreciated. This is a production environment and losing workflows is critical for our operations. Thanks for your support :wink:
following this up cos i experienced similar data loss with SQLite-based n8n installation
Same I thought when I was arguing with h.s.tngeer support, saying that is everything OK, but my corrupted db wasn’t!
Lost 2 days of intensive work…
They suggested as well to use FQLite (SQLite Forensic Toolkit) or the SQLite CLI to check corrupt files.
Highly RECOMMENDED!
Yea… just backup the .n8n with a bash script(sometimes I do it hourly :laughing:.
