Write binary file when using n8n workers
Hello everyone,
I have a workflow that download big CSV files on FTP, then split in batches to store locally in /tmp folder all parts of the file.
After that i’d like to use another workflow with Local File Trigger, checking for added files in /tmp.
My problem is that the files are written in the /tmp folder of the worker node that handle the first splitter workflow and the local file trigger is not triggering.
Can you help me to have the Local File trigger working when using N8N workers ?
Thanks and regards,
  • n8n version: 0.236.3
  • Database (default: SQLite): Postgresql
  • Running n8n via (Docker, npm, n8n cloud, desktop app): K8s/docker 1 pod for GUI and 10 workers
Hey @Alban_TUAL,
Best thing I can think of would be to use a volume or bind mount and share that between all of your workers that should then resolve the issue.
