The n8n ‘Write File’ node fails with a ‘not writable’ error when writing to /home/node/.n8n/
Problem in node ‘Read/Write Files from Disk‘
The file “/home/node/.n8n/success.json” is not writable.
n8n version: 1.110.1
Database (default: SQLite):
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: Pop! OS
krisn0x
September 11, 2025, 3:05pm
2
Hey!
Unless you run the container as the root user, you won’t have access to write in /home/node/.n8n. It’s not really recommended, as if an attacker takes control they will have sudo access. Here’s how:
docker volume create n8n_data
docker run -u 0 -it --rm \
--name n8n \
-p 5678:5678 \
-e GENERIC_TIMEZONE="<YOUR_TIMEZONE>" \
-e TZ="<YOUR_TIMEZONE>" \
-e N8N_ENFORCE_SETTINGS_FILE_PERMISSIONS=true \
-e N8N_RUNNERS_ENABLED=true \
-v n8n_data:/root/.n8n \
docker.n8n.io/n8nio/n8n
*Notice the -u 0 (root user) and -v n8n_data:/root/.n8n (moving .n8n under root, so the root user has access)
Recommended way would be to create a docker compose file. Inside create a second volume to which you will have write access:
volumes:
- /n8n-data:/home/node/.n8n # you can't write here
- ./n8n-output:/data # you can write here
Let me know if this help and feel free to mark as solution if it did
Thanks, I included the second line in volumes. It worked perfectly. And I got the written json file in the n8n-output folder.
