I noticed something awkward. It seems that the predefined X OAuth2 API credentials have only 14 scopes available:
tweet.read
users.read
tweet.write
tweet.moderate.write
users.read
follows.read
follows.write
offline.access
like.read
like.write
dm.write
dm.read
list.read
list.write
However, I need the media.write scope to upload images/videos.
I tried to set up a generic OAuth2 API credential type with both media.write and tweet.write (+offline.access), but they don’t seem to work combined, and I always get an error like “Forbidden - perhaps check your credentials?” or “The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.”
So that made me set up two OAuth2 credentials, one for each scope.
However, everytime I have to run the workflow I have to reconnect both credentials. I guess it’s because of the refresh token flow.
Anyone else have the same problem?
“errorMessage”: “Forbidden - perhaps check your credentials?”,
“errorDescription”: “Forbidden”,
“errorDetails”: {
“rawErrorMessage”: [
“403 - "{\n \"title\": \"Forbidden\",\n \"type\": \"about:blank\",\n \"status\": 403,\n \"detail\": \"Forbidden\"\n}"”
“httpCode”: “403”
“n8nDetails”: {
“nodeName”: “Post to X”,
“nodeType”: “n8n-nodes-base.httpRequest”,
“nodeVersion”: 4.2,
“itemIndex”: 0,
“time”: “12/02/2025, 09:31:46”,
“n8nVersion”: “1.77.3 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeApiError: Forbidden - perhaps check your credentials?”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V3/HttpRequestV3.node.js:525:33)“,
" at processTicksAndRejections (node:internal/process/task_queues:95:5)”,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:633:19)“,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:882:51”,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1216:20"
or
“errorMessage”: “The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.”,
“errorDetails”: {
“httpCode”: “EAUTH”
“n8nDetails”: {
“nodeName”: “Post tweet on X”,
“nodeType”: “n8n-nodes-base.twitter”,
“nodeVersion”: 2,
“resource”: “tweet”,
“operation”: “create”,
“time”: “12/02/2025, 08:01:16”,
“stackTrace”: [
“NodeApiError: The request is missing a required parameter, includes an invalid parameter value, includes a parameter more than once, or is otherwise malformed.”,
" at ExecuteContext.twitterApiRequest (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Twitter/V2/GenericFunctions.js:41:15)“,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/Twitter/V2/TwitterV2.node.js:171:40)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:632:19)”,
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:881:51",
" at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/execution-engine/workflow-execute.js:1215:20"
- n8n version: 1.77.3
- Database (default: SQLite): postgres / redis
- Operating system: windows 11
