I think there may be an issue with the Xero node when select to create invoice. After I upgraded from 0.171 to 0.185 the Xero Node needs ‘Tax Type’ to have a value, which is fine accept the only value that maps to Xero is ‘Tax Exempt’ all the others fail. Tried to create a value to match in Xero defaults but still no good.
Hi @paul2000, I am sorry to hear you’re having trouble. Any chance you can share your workflow and confirm the country your Xero company is set up for? Also, can you confirm the exact error you are seeing?
[{“Message”:“The TaxType code OUTPUT does not exist or cannot be used for this type of transaction.”},{“Message”:“The TaxType code ‘OUTPUT’ cannot be used with account code ‘200’.”}]}]}"
I think the best scenario would be to share the workflow, if that would be possible? You can share the workflow by just copy & paste. Refer to the link on how to Share a workflow.
I have tried the node again and it is still working for me. I think the issue here is that your actions might not be supported by Xero. You might want to give it a shot and contact Xero support. Have a look at this discussion maybe it can help you.
