With just a little customization the Zoho module quickly becomes unfunctional because admins tend to create custom modules. For that reason I find myself using the http helper allot!
In addition to that the zoho api is finicky and the web is riddled with people complaining about getting 400 bad request, and 400 missing parameter errors.
In the code block here are a few zoho api requests, and they always return errors. but I cannot figure out why. Then I looked at this page in the code base. under scope it says would adding scope to the zoho credential be as easy as adding it right here? one additional important scope which I am trying to make work is coql (the zoho query language)
here is a list of additional scopes available by zoho
Summary / Actual Problem Statement
I have not been able to get any post request working with zoho even when I build the body by hand, I have however been able to make get requests work.
Second, COQL and many other scopes are not available through the credential… any Ideas on how to add them?
displayName: 'Scope',
type: 'hidden',
default: 'ZohoCRM.modules.ALL,ZohoCRM.settings.all,ZohoCRM.users.all',
Please share the workflow
If anyone has personal experience making zoho work in N8N I would be happy to pay for a consulting hour. Getting COQL to work is a big deal.
