@MutedJam Same issue I get “data: []” when listing streams. I am using a generic bot by the way. I have tested with an API key and it works. However it is not the proper way using Zulip for automation.
Tanks for confirming @GhaziTriki. Can you share how exactly you have configured your bot?
I just tested the Zulip node with a generic bot (without additional settings) and didn’t run into any trouble either:
Apart from that, using expressions to overwrite dropdown field values should be fine, I have suggested it a few times here on the forum for other nodes
You can ignore that error. I restarted the docker service after a system update and everything went back to normal. However I can’t get streams listed.
Hi Ghazi,
We can’t replicate your error even with the logs you provided. The streams are listed fine and the topics are listed according to the selected stream. Since it is a pre-populated field you can overwrite it using “Add Expression” and thus create a new topic. Then you can remove the expression again and select this topic from the dropdown, should you wish to do so.
If I did not get your request right, please provide more detail and I will do my best to help you out.
