Add Due Date Field to Jira Create Issue Node
The idea is:
The addition of a “Due Date” field in the Jira Create Issue node.
My use case:
When creating issues in Jira through n8n, it’s currently not possible to set a due date directly from the workflow. This is a key field for tracking deadlines and is essential for managing tasks effectively, particularly in projects where time management is crucial.
The “Due Date” field is an important attribute for task planning and management in Jira. Without this field, users must either use an HTTP Request node to call the API directly or manually edit the issues in Jira after they are created.
No
This feature is must needed for jira. And also if there an option to add custom tags on json the going to be published to the jira without HTTP node
