Add Editor Option/Preference to Place First node at Left or Upper Left
The idea is:
Add a preference setting (in Personal Settings) for the workflow editor, to allow each user to customize the "Position of the first node of a workflow". Currently the first node is always centered in the editor. Other options for this would be "On the left edge", or "In the upper-left corner".
My use case:
For every new workflow I make, I end up following these steps.
  1. Add the first/trigger node
  2. Add one or two other nodes and run out of editor space because everything is positioned relative to the middle of the editor (using only the right side, or lower right corner, of the editor space).
  3. *** Drag the entire workflow to the left, or up and to the left.
  4. Continue adding more workflow nodes.
It would allow a user to set things up to eliminate the need to reposition every new workflow nearly immediately after creating it.
n/a
no
