Add Langsmith configuration ability to work along side LangChain AI tools framework
I saw that there was a feature request for this already, but the topic was closed and I was unable to vote on it.
So I am recreating the post with a bit more detail.
The idea is:
Add capability to configure LangSmith to N8N.
Langsmith supports in depth LLM data tracing, dataset tracking, and performance measuring.
My use case:
Needing to be able understand not only my n8n workflow performs but also how each agent performs in LLM calls as I increase usage of my workflow.
Since Langchain and Langsmith are designed to work together, I think the benefit here is to have more insight into your AI workflows and compare different LLMs, if needed.
With all the progress n8n has made with integrating AI tools adding logging/analytics would be really useful.
It’s one of the reasons I’ve been considering other workflow tools such as Flowise / Langflow.
Langsmith would be great, but Langfuse would be even better. More cost effective hosted plans and the ability to self host.
