Add Node for Exit workflow without executions entry
The idea is:
Add a simple node, like “No Operation, do nothing”, where you exit the workflow, but add no executions status sucess entry
My use case:
I have 20 Cron Workflows, which check a “queue” every minute, by 20 * 60 * 24 = 28800 Entrys every Day, you wouldn’t find an execution with real data, you can only see it on “Running Time”.
I think it would be beneficial to add this because
It would save a lot of database operation and load, also you have a better overview of your executions.
+1 would love to see this. Useful for cron jobs, but also for webhooks and triggers where you can’t filter at the source. Instead you have a bunch of IF nodes at the start of your flow that drop most of the events!
Up!!
For me, this scenario is quite common, having executions that “do nothing” pollutes the workflow execution history.
