The idea is:
The existing Webflow site publish node makes the site ID available. If available, it would be helpful to have the site name too as that would be more meaningful in some cases.
It would also be helpful to know if the site was published to staging, the custom domain, or both. (Not sure this is available from Webflow.)
My use case:
I am trying to send updates to a channel when certain Webflow actions take place. This additional context would be helpful in understanding if merely development changes are underway or changes that site visitors can see.
Can set up notifications so that collaborators know when a site has updated.
I can help test, but not create the functionality.
