Hello! I have recently started doing some tests on n8n, and I would love to get some help please. I have been trying to create a local multiagent enviorment using ollama that basically consists on four agents. The first one is going to rewrite the user input to upgrade it. The second agent is going to generate a sql code for that new input. This code will be executed on the database (named superheroes). And here lays the question. The third agent is just going to comment the results of the code, nothing more. However, the last agent needs to write some Python code to create a bar chart (or the most suited type) for the outcome. This same code should be executed on n8n to generate the chart. I have been trying to use Quickchart as a tool, but I dont have any idea if this is the correct path. Lets just say, if the results from the SQL code are
Id |apparitions_number|
|1 | 10 |
|2 | 21 |
|3 | 34 |
|4 | 4 |
The X axis should be id, and the Y one should be the apparitions_number. The pythonc code should be capable of doing this. And then execute via Quickchart
Received tool input did not match expected schema. I try to return the outcome to the agent, but it just keeps sayhing things like that. I dont know what Im doing wrong, or what kind of modification could be done.
- n8n version: latest version
- Database: mySQL
- n8n EXECUTIONS_PROCESS setting (default: own, main): own
- Running n8n via (Docker, npm, n8n cloud, desktop app): npm locally
- Operating system: Windows 11
