I’d like to ask for some help please. After hours of playing and google/chatbot/forums, I’ve coome here for help
I have a working workflow using an AI agent with OpenAI/Gemini Chat model and a Playwright MCP Tool. I am hosting my own n8n and Playwright MCP servers.
I am using it for web crawling/automation and can type requests into the chat window and the AI/Playwright MCP server can crawl / scrape web pages successfully.
I can type “Login to www.domain.com with username:MrBlobby and password:dontshare and the AI uses this just fine to login to the website.
However, I dont want to pass the credentials to the AI Chat as this feels very insecure. I have been trying and failing to find a way to save n8n credentials that I can pass on more securely.
Does anyone have any tips or code I can use to make this happen please?
Hi. Anyone have any idea how I can achieve this please?
I have looked into the getcredentials method but it seems to not be available for me to use:
async function main() {
try {
// Replace 'genericCredentials' with your credential type and 'WebsiteLogin' with your credential name
const credentials = await $.getCredentials('stored-creds');
return [{ json: { email: credentials.email, password: credentials.password } }];
} catch (error) {
throw new Error(`Failed to fetch credentials: ${error.message}`);
return main();
Hey can you tell me how did you get the MCP working. I am trying but unable to call as playwright mcp needs proxy for http calling. Adding MCP only supporting http streamable
I run self-hosted non-docker, test environ. my n8n does NOT have the new fancy “variables” section.
I grab env variables at n8n startup, via a bat file. I start n8n, a couple other things.
Bat file has code section like this:
set ENV_FILE=C:\Users\YOURPATH.n8n.env
:: 1. LOAD .ENV
if not exist “%ENV_FILE%” (
echo ERROR: .env not found at %ENV_FILE%
pause & exit /b 1
echo Loading %ENV_FILE%…
for /f “usebackq eol=# delims=” %%L in (“%ENV_FILE%”) do (
set “%%L”
AND i have an env var set: N8N_BLOCK_ENV_ACCESS_IN_NODE=false.
see vid - i put env var wherever i may need in a flow, and the UI complains** it says not accessible! Then it goes ahead and runs, resolves fine. Here i demonstrate a Slack message firing off to url
Your $.getCredentials idea was actually right, like you were so close.
Drop the dot — it’s $getCredentials() not $.getCredentials(), I’ve done this myself tbh. And um, you need to create a Generic Credential in n8n’s credential store first, the name you pass in has to match it exactly.
Stick that in a Code node before your AI Agent, then in the system prompt just reference it:
When logging into domain.com use username: {{ $('Code').item.json.username }}
and password: {{ $('Code').item.json.password }}
Credentials stay encrypted in n8n, never touch the chat. Does exactly what you wanted.
Oh and if you’re on a recent version of n8n there’s an even easier way — Settings > Variables, add them there and just use {{ $vars.SITE_USERNAME }} anywhere in the workflow, no code node needed at all.
The env variable thing mentioned above works but it’s a bit of a faff honestly.
