AI Agent Node Creates a New Redis Connection on Every Execution (Redis Memory Not Persistent)
Hi team,
I’m facing a persistent issue with the AI Agent node when using Redis Memory in n8n.
Problem
Every time the AI Agent node runs, n8n creates a new Redis connection, even though I have provided a valid Redis Cloud connection config. This results in:
  • Multiple Redis connections per workflow execution
  • Significant performance overhead
  • Redis Cloud warnings about too many concurrent connections
  • No reuse of existing Redis clients
Environment Variables Used
I have set the Redis Cloud details in my self-hosted instance:
QUEUE_BULL_REDIS_HOST=
QUEUE_BULL_REDIS_PORT=
QUEUE_BULL_REDIS_PASSWORD=
QUEUE_BULL_REDIS_USERNAME=default
These variables work for Bull queues, but the AI Agent node still creates a new Redis client on every execution.
Expected Behavior
The AI Agent node should:
  • Reuse a persistent Redis connection, or
  • Provide a way to share a Redis client between executions
  • Avoid creating a new connection per request
Actual Behavior
  • AI Agent node instantiates RedisChatMessageHistory
  • It creates a new Redis client
  • It connects → reads/writes → closes
  • This happens for every single execution
Impact
For high-frequency workflows (WhatsApp bot, chat agents), this becomes a major scaling issue.
Attempts Made
  • Added Redis env variables
  • Tried worker mode
  • Verified Redis Cloud configuration
  • Confirmed that Bull Queue Redis ≠ AI Agent Redis
  • Tested with self-hosted Redis and Redis Cloud
The issue remains: AI Agent memory does not reuse the connection.
What I Need
  • Clarification: Is persistent Redis connection pooling supported for the AI Agent node?
  • If not, can this be added as a feature?
  • Or can the node be updated to accept a shared Redis client instance?
Why This Matters
Other nodes allow global objects in the Function/Code node, enabling singleton Redis clients. But the AI Agent node is fully encapsulated and doesn’t expose any way to reuse the connection.
This makes Redis Memory nearly unusable in production cases where frequent requests occur.
Thanks!
Hoping to get guidance or a fix for enabling persistent Redis connections in the AI Agent node.
The AI Agent node creates a new Redis connection per execution because it instantiates RedisChatMessageHistory internally without connection pooling. This is a known limitation—n8n does not currently reuse Redis clients for AI memory across executions.
Your env variables only apply to Bull queue, not AI Agent memory. There is no built-in way to pass a shared Redis client to the node currently.
Workaround: use an external memory service with HTTP endpoints or switch to in-workflow memory storage if conversation volume allows. File a feature request on n8n GitHub for connection pooling support in AI memory nodes.
