Hi !
Our current setup uses an AI Agent node connected to an OpenAI model.
Workflow test Cout - n8n - Google Chrome1310×837 178 KB
By default, the AI Agent node only returns the raw text from the model response.
What we need is to retrieve both:
the raw text output, and
the model usage information, such as completionTokens, promptTokens, and totalTokens (i.e. per-model usage metrics across our project).
Is there a way to extract or access the usage data for each model when using the AI Agent node?
Thanks !
