AI agent not accepting data when using Google Gemini chat model
Running the LLM chain with a Google Gemini model now returns a result that says:
    "text":
    "I need the content of the two JSON objects to provide a response. Please provide the content of the "Proposal Feedback" and the "External Source Document.""
I am passing the json objects from previous nodes in the user prompt and also passing instructions to the llm in a system prompt.
This is happening primarily with the Extract Insights LLM node
There is no error message
N/A
  • n8n version: 1.90.2
  • Operating system: Mac OS Sequoia
Ola @
Passe o contexto no formato esperado conforme o erro tem pedido
  "Proposal Feedback": "... conteúdo ...",
  "External Source Document": "... outro conteúdo ..."
I hope I have helped in some way
Okay so I am passing it that way in the prompt however I still get the same error.
After playing with it and researching, I see the data being passed to the LLM shows as [object Object] rather than the actual data within those objects. Maybe I am doing it wrong. Would it be better to send the data as a string rather than an object?
Edit
I decided to use JSON.stringify while passing the data and it worked.
Hi @ahmedfaaid
Excellent insight, because stringify forces JSON recognition
You did great!
Congrats!
Please mark the post as solved (blue box with check mark) so that this ongoing discussion does not distract others who want to find the answer to the original question. Thanks
