AI model node not connecting to Azure OpenAI API
Azure OpenAI API deployment isn’t connecting. It shows resource not found despite placing the correct resource name. The n8n documentation isn’t much helpful as it gives the base guidelines only.
Resource not found
The AI model node in the AI agent is having the issue.
Hi Haroon,
Difficult to judge without more info but have you checked the credentials for the Azure connection ? I must admit that I have not used this node but this sort of error is usually because the endpoint is not specified correctly. Also, the n8n node sets the version to “2025-03-01-preview“ by default but the current version in the Microsoft docs is “2025-04-01-preview“.
Hope this helps.
S
